pandamotion
Can anybody help, my selecta transmission has started making a funny noise. Laugh all you like, but it sounds like there is somebody inside it blowing on a party squeaker
Now here's the thing, it doesn't do it all the time, but it does do it in park and neutral, so to my mind it has to be something to do with either the pump or the valve block as everything else is stationary in park. I did try to take a video of it as hearing the noise is easier than trying to describe it, but no, because I want it to make the noise it won't
If you have ever heard the noise a brake servo makes when the diaphragm fails (kind of a sucking reed sort of noise) then that's what it sounds like, so much so that my first test was to disconnect the vac line to the servo. so far I've changed the fluid so I know it's the right stuff, adjusted both cables, cleaned up the switch and confirmed the clutch is Ok. What ever it is, it does not affect the drive at all (yet), she still goes like stink, so if anybody has come across this before or has any ideas then they would be gratefully received.
