Technical Burning smell from rear after changing pads
Hello guys.
I have a Fiat stilo 1.6 from 2002 and i have just changed my waterpump and my rear break pads,
well the error is that when i have driven for about 10 min it smells like something is burning from the rear, is that normal when the break pads has been changed or is something wrong?
hope you guys can help me:slayer::):p
QUICK TEST
On flat ground, take handbrake off and make sure you can push the car easily then you know your brakes aren't binding excessively
If you didn't change the discs too then there will be hot spots where only very small part for the pad will be making contact with the disc so this will get much hotter and quickly until it beds in to match the disc
Keep an eye on it- you don't want smoke out the rear or discs changing colour
