To be honest I cant even remember why the dremel thing was there Alex
... I know I did some soldering to a retro VW dash fan on the right rear ring in the afternoon... which is why I had turned the ring up on full, to burn off the flux... oh yeah :idea:, I was modifying a BT home hub phone charger with the dremel earlier on...
left it overhanging the left rear ring on the hob... thought I`d turned on the RR ring on, I`d in fact turned the LR ring on... went in the living room to check my email while the ring warmed up... then the smell of burning plastic... & an instantanious white fog decended throughout the place setting off the smoke alarm.... the dremel thing was deposited in the bathroom sink & several fans were turned on to disperse the smoke...
2 stupid things I would
never usually do, both within an hour of each other... unbelievable... I blame my currently broken (& hurting) tooth... :bang:
I will attempt to blend it in, but if its not 100% then Ill have to respray or it`ll drive me mad, the paint on my Uno, although exceptionally good for 20, is obviously aged, so new paint on 1 wing will look wrong....
All my cars have been damaged outside, including the Uno (rear bumper had tow bar & scuff damage, NSR light lens was cracked - both thanks to neighbours parking by `feel`- & 1 mirror was kicked off by local chavs), my Jags had even more damage to 1/2 its panels, by the same neighbours & chavs) & is gonna need a respray soon too.
I like my cars looking mint, I`m a bit of an OCD sufferer like that
I did put another rear lens on the Uno`s light, but it was the later, slightly darker tint lens, that also drove me mad, I had the other side dark tint lens, but I prefer the light tint lenses, so, I ended up supergluing the cracked one so both rears matched again...
Check out the tow bar marks in my rear bumper (& the odd tint rear lights before I changed it back) & the kicked off mirror...
OCD... its a right pain in the arse...
I have to admit I did laugh out loud at the description of the Dremel thing being burned out when you turned the wrong ring on. The real question here is, what on earth was the Dremel-imitation-tool doing in the kitchen... and on the cooktop...! Time for a kitchen tidy-up methinks
But as for the scrape, oh go on... touch it in with several layers of paint applied by a toothpick over several days, a quick sand with 1500 grit and a polish, and try to forget about it...
It's even more frustrating when you wash your car and notice similar-depth chips in the doors, etc. caused by supermarket carpark damage that weren't there a week ago. All you can do is keep the touch-up paint ready... otherwise you'd be doing full resprays every year or two...
-Alex
