Technical Bsi checking
Luke the duke
Heya
I'm a little worried about taking out the bsi to check if its been damaged and the cause of my indicator / highbeam troubles. Anyone done it? Pictures? Advice? The haynes manual only shows taking off the fusebox.
Also anyone have dealings with bba or ecu doctor, getting it fixed?
There is no real possibility for me to do a scrappy swap, its still winter here in Finland and im working in the apartment carpark! Also Mot in a few weeks time. If its broken this is probably going to be the best option for me.
Thanks in advance.
Luke
Hi Luke,I have taken my out and it is quite easy. There are 3 screws holding the fuse box and bsi in.It is a little tight getting it out then the bsi unclips from the back of the fuse box
