G'day ROJ, just checked my manual and it states..
quote: "If you need to add fluid, only use the type classified DOT 4. You are advised tn particular to use Tutela TOP 4 270 C with wich the braking system origionally filled"
If I get my scanner working and am bored 1 evening... I will send you an English version of the manual if this would help you...
I'm not sure but I expect the "Tutela top 4" Is the brand name used in Italy...
I would recomend using whatever DOT 4 fluid is available in the UAE. I believe DOT 3 is NOT INTERCHANGEABLE but may stand to be corrected...
Also I think it's possible to upgrade to DOT 5.1 ???? (my last car used DOT 4 but most people used 5.1 as it could be interchanged and used at a higher temp... but please wait untill you hear an experts oppinion on this.
