L14MNP
- Joined
- Oct 2, 2010
- Messages
- 8
- Points
- 4
Hi guys.I've had my winter rounaroud 98 Seicento Sporting a couple of months now and all is pretty much well. It does the job I picked it up for no problem.
I have a couple of niggles, but nothing I really CBA to sort out.
I just noticed this morning that the bottom window seal/scraper on the drivers door is bent out at the end nearest the handle and I have two random sideways fingerprints on the glass. I haven't looked in too much detail but I'd guess someone has attempted to gain access to the door rods. A lot of ice does build up on that seal, but I doubt it has expanded and caused this. When I push the seal back the whole door skin moves with it.
Anyone had similar? Also are these things deadlocked? They may have already been inside for all I know. It will be just my luck if they took my coilover spanners and damper adjusting rod for my other car! Will have to check glovebox shelf for that.
I would assume bending the door frame back on a car like this would be the chosen method of entry for these little scrotes.
