I will check whether it still starts tonight when I check the brake lights ty, the year is 08Does it crank over but not start? Accelerator pedal positioner could be a problem as per pic what year is it?
Right it starts fine but says on the screen-check engine and rattles a bit when switched on although when I did it again there was no rattle.Thats a fair mix of reported errors..
No other warning lights..or messages recently ?
Do let us know what does and doesnt work
Do you hear the loud pump whirr as you open the door?
The fuel pump ( under back seat) whirr for 5 to 10 seconds..as you turn ignition on ?
It starts fine-no probs-seems to let me select a gear, did say check engine the first time I switched it on, can’t see any unusual lights or anything in the dashboard,no noises of any sort except the first time I did it, was rattly but ok now,I believe the 169A4000 engine is normal for a 1.2 500 as well as the 1.2 Panda.
So... starting with the "free" simple ones:
Does it start?
If so, will it let you put it in gear?
If it won't start, can you still select gears?
Are there any messages or unusual lights on the dash?
Is it doing anything unusual (clicking, buzzing, not buzzing when you open the drivers door when it used to buzz, etc.?)
When was the new battery fitted?
Was the main earth cable checked/replaced?
More details are needed to get any further forward, of which getting the codes read from ALL modules would be most helpful. (Most cheap generic code readers can only read the engine ECU, which may not show the problem)
(Overlapped with @varesecrazy above - slow typing on phone to blame!)
From that it looks like a pure engine-related issue, rather than anything to do with the gearbox, which is good news.It starts fine-no probs-seems to let me select a gear, did say check engine the first time I switched it on, can’t see any unusual lights or anything in the dashboard,no noises of any sort except the first time I did it, was rattly but ok now,
The new battery was fitted last September by a mechanic friend-he didn’t mention anything about an earth cable.
Am I best off taking it to a fiat garage to get it hooked up to the right machine?
Oh ok-wasn’t expecting that!!From that it looks like a pure engine-related issue, rather than anything to do with the gearbox, which is good news.
Have you checked oil & coolant levels? Bit worried about the "rattle", but without hearing it , it could be anything.
My best guess (and it is only a guess) is that its an electrical problem - main earth cable, or tailgate wiring problem. (Or a failed battery, but less likely)
Did you have the steering wheel symbol come up on the dash recently?
Any strange things happening (wipers randomly working, etc.)?
Ok tysm for all your help I will give this a go.So check all the basics, turn off the headlights, replace the engine earth strap it will need one if it's not been replaced.
Anyone, if the ecu doesn't know the accelerator pedal position will it trip out ?
A temp fix/test for the earth strap is a jump leads from the battery NEGATIVE to any good earth point on the engineOk tysm for all your help I will give this a go.
Tacho indicates engine running?I did notice in your 'speedo pic' that there are no oil or battery lights..
So assume the engine was running..
That Yellow engine symbol shouldnt be on.. its often related to 'emissions'..
Might explain your 'lack of OOMPH..'
Back to Coolant and oil checks..
A torch..phone flashlight ..is ideal for the coolant
