Andysan
- Joined
- Oct 7, 2010
- Messages
- 503
- Points
- 121
So after my Bravo spent two and a half weeks at HM AC's pleasure having its new flywheel and driveshaft parts fitted, along with its oil leak I had hoped and prayed that I was now surely owed many months of trouble free driving. Well apparently this is not The Fiat Way, as eight days later I've noticed that my Bravo is either very nervous or simply getting on a bit as it keeps wetting itself at every available opportunity.
The culprit this time - the washer jets, most notably this rubber connector here which I cannot get to seal back up:
Depending on the orientation of this pipe, fluid either sprays through the crack in the bonnet and onto the back of the car in front of it on my driveway, or directly into the fusebox (which someone has broken the casing on meaning that it is not watertight).
Yep, I know everyone will say its minor and I agree that it is, but it just feels like another brick in the wall in the never ending reliability saga that I seem to be experiencing with this car.
Does anyone know if I can procure the part in question from anywhere other than Fiat please - I could just tape it back up but would be constantly checking it to see if it was leaking. Failing this my first MOT is in two weeks so I could just get the garage to look at it then. I've read that the following is required to pass the inspection:
I reckon that the washer jet is operating properly, the fact that it goes into the fusebox and not onto the windscreen is just down to the gods! :worship:
Wipers and Washers must operate properly and give the driver a clear view of the road.
