(1) the lower steering cover removal of this cover must be snapped. Underneath-Two Torx screws must be unscrewed.
The third screw
(2) to remove the upper steering housing remove these two bolts
(3) the cruise terminal tracing usual place if the car is in preparation.
the two plastic retaining clips snap off, then fuzz out the plug to drag on the left side of the cruise control lever. The locking tabs and then snap back.
(4) go to the bottom of the cruise control lever fixing bolt 12mm short.
You need to remove the screw. go to the top cruise control lever tab. here will be a longer 24mm bolt
(5)
The cruise control lever in place. The top bolt shown in the picture, were taken from an earlier screw.
(6)
connect the cruise controll by pushing it in, the lower screw is around here
(7)
the connection in place
(8)
Replace the top cover and bottom cover with the cruise control
(9)
ermmm... Enjoy it
:slayer:
