Hi guys
had a problem with the fan not working, do i took it to my mates garage, he tested a couple of things, relays etc and we came to the conclusion that it was the sender (by the thermostat) changed it went to start it and know the engine management light is on, it turns over but won't start.
Is there a flash test i can do to get a code or anything as my mates snap on scanner is 16pin and my car is three pin obd. Without a fault code i'm peeing in the wind. I also reset the ecu and reset the fuel cut off switch with no joy at all. checked the wiring under the relays (infront of the battery) and everything seems ok there.
Help or advice is much appreciated.:worship:
Thanks in advance for your time
