I bought my car about a month and a half ago and it all seemed fine. I was sitting in traffic the other day and noticed the engine was running a bit hot so i stuck the heaters on full which cooled it down fine. then the heating system cut out so i pulled over and let everything cool down. Got it back home and had a look around under the bonnet, couldn't see any leaks so i tryed bleeding the system. I got nothing from the radiator bleed valve and only steam from the heater valve. I drained the whole system and took the thermostat off for testing. The valve seemed to be opening fine, letting plenty of water through, then closing firmly when cooled down. I flushed the radiator and blew through the heater return pipe to check for blocks but they both seemed fine. I then put the thermostat back on and refilled the system. I couldn't seem to bleed the system properly and was again only getting steam from the heater bleed valve. I tested the pipes for heat and found the heater return pipe was not getting hot so i took both pipes off and connected them together to bi-passed the heating matrix. I tryed bleeding the system again but was still only getting steam. I don't think i've got a problem with the coolant pump as i'm getting plenty of pressure in the system. i've also checked for a head gasket faliure and dont think thats the problem.
I also noticed quite a loud knocking coming from the header tank, not sure whether it is bubbles or somthing in the system (i can't see anything in the tank). The fan seems to flick on and then go straight back off agian when the engine is warm. i put a short across the teminals of the radiator thermister and the fan works fine so possibly a dodgy part there. i also noticed that the bottom header tank hose was not getting hot, even though the radiator is??!! Anybody got any ideas for what i can try next?
