3-4 months ago I had a problem with the engine it would just seem to die for a split second while under load. So I changed the spark plugs with no joy and then changed ht leads and reset ecu this work for about 70 miles before symptoms returned at which point I replace the lambda sensor which seem to work but the engine idled slightly uneven and felt flat up to 3500rpm (as if the diaphragm on a car with a carb had split but I believe this does not have one) and now has started to die again. Any ideas of what to try next?
Thanks.
Thanks.
