Hi All,
wondered if anyone can help.
went to change the front brake pads today as a grinding noise started to occur every time i used the brakes. 2 things then happened:
1 - i couldn't pull the clip out of the caliper pin as the pin must have rotated so the ends of pin were sticking out - i could push them thru - i presume there isnt enough room. so i tried to rotate the pin but couldn't get any grip with the pliers so had to give up.
the second thing is that as i was driving home the grinding got worse and you could hear the rotor rubbing at low speeds - think it might have warped slightly.
when i turn a corner at low speeds the grinding increases/starts even when i havent touched the brake.
any ideas/advice?
cheers
any ideas/advice?
cheers
