looking for a brake upgrade for my sporting mk2b 1.4 ive looked at the 284 set up from a hgt just intrested if anyone has done this or knows of any other upgrades that have been done over the years
HGT brake setup should be fine with all standard 15" wheels which a Mk2b sporting will have.
does your 1.4 have vented front discs? any standard punto brakes should fit your car but remember that the brakes are only as good as the tires you have fitted so if you can lock the wheels (or kick the ABS in) then you don't need bigger or better brakes, and rear discs look better aesthetically but add nothing to braking performance as the car stops on the front brakes
