brake trouble
brake trouble
J
johnboy
just converted my bravo 1.8 hlx toa 16v turbo and for some reason my rear brake lock way before the front any ideas anyone?
also my abs light is on but i know this is on because i have broken the 2 front sensors trying to remove them could there be a error in the abs unit??
What the locking of the rear brakes go, you have to adjust the brake pressure proportioning valve, all bravo/a have them till 1999, after that they came with EBD+ABS.
What the ABS light goes, if you didn't replace the sensors, or used wrong ones, or they ain't working right - you automatic have a fault.
Members Site ---------My Site
well its a x reg i know the abs int working as i have got no front sensors in but why would the rear end be locking up before the front?
i am a mechanic and i cant find the valve any where i was wondering if the valve is in teh abs unit as i have found a torx screw but dont wanna play untill i know its right
Number 10 on the pic - for further info you will have to wait till afternoon.
The valve is located (if you dont have EBD) on the ""rear axle"".
i have ebd so i need to adjust that if it akew the fuse out of the abs unit will i go to a standard setting?
If there is no valve - you have EBD and dont have to adjust anything.
What the ABS goes, when the light is ON the ABS is OFF. So you have regular brakes.
Did you do anything else on the car except the engine swap ?
it got the full coupe front end on disks pad calipers all blead up ok and when you put the car on the brake rollers the fron brakes work fine its just the back locking up everytime you press the brakes
when i code read it it say main relay circuit p0047 any ideas
P0047 = Turbocharger(TC)boost control solenoid/ supercharger(SC) boost control solenoid - circuit low.
Wiring short to earth, TC/SC boost control solenoid.
its the abs unit what i am reaing to get that code and its sayin main relay unit
Dont know whit what diag equipment you read out the code, and do you have a OBD plug or normal 2wire fiat one, but its the only code I found.
And what the relay goes, its on of the relays right of the steering wheel where the fuses are, plus like Tom said, fix the sensors first, it may be that all will be OK after new ABS sensors.
you WOT!!!!
I converted that to a 16vt u tit!!!
trying to take all my glory lol u wait now!
lol
lol am coin round to yours later i want ur basic map chip think myn is over fueling and you dint do it all lol
T
2
365
L
I
873
ian gardner
I
B
2
603
Sabre 23
S
C
1
844
Tristan
T
