Hello,
I have a set of rear brake calipers labelled 4181971 as the part number.
A quick google search identifies these as from a 124 Spider - however I cannot identify which Discs and Pads are required to go with this brake caliper.
Unfortunately the vehicle in question is not a 124 - It is in fact an X1/9 - with the Faran Eliminator kit (can be seen in the X1/9 section of the forum!) so I cannot use most parts locators as they need a Reg number or a specific model - which I am not able to provide!!
Can anyone help - for instance do you know if this caliper is fitted to your 124?
If so can you please provide the year/model/engine size so I can record this and use to order some new discs and pads?
Thanks in advance
AdRocky
Thanks in advance
AdRocky
