M mandinga New member Joined Oct 18, 2004 Messages 6 Points 2 Oct 18, 2004 #1 Hello ... bought a '94 Fiat Uno yesterday. There doesn't seem to be a lock for the boot, can someone let me know how you unlock and lock the boot? Thanks
B Bushboy Chris Parked in the garage Written a guide Joined Oct 2, 2003 Messages 9,933 Points 2,037 Location Cheadle, Staffordshire Oct 18, 2004 #2 depending what model you have, there may be a lever by the drivers seat to open the boot. you should definatly have a lock on the boot though (unless its been delocked in which case ask the previous owner how to open it)
C chrisunoman Prominent member Joined Mar 26, 2004 Messages 3,134 Points 532 Location Manchester Oct 18, 2004 #3 I take it your boot is the same as mine if its a 94 Uno. The boot lock is just above the number plate, once u turn the key, press the square button.
OP OP M mandinga New member Joined Oct 18, 2004 Messages 6 Points 2 Oct 18, 2004 #4 Thanks for the info ... I will check tonight and let you know!
OP OP M mandinga New member Joined Oct 18, 2004 Messages 6 Points 2 Oct 18, 2004 #5 Found out that there is no boot lock! It looks like it has been removed. Can someone also let me know whether it is easy to fit a new lock? Also the catch that secures the sunroof doesn't work properly ... is it easy to replace? Thanks Mandinga
