General Boost Sensor
brummy
Hello all
can you tell me where the boost sensor is on a stilo 1.9 jdt 2004
As I'm still having problems with power
New AGR
New Mass Air Flow Sensor
Boost sensor is the MAP sensor on the back of the inlet manifold. It's secured with one RIBE screw.
From the previous thread you put on the forum you may be interested on the information found in the link below for the boost solenoid valve, details found in the guides section as informed in previous thread, also any fault codes are very much an added advantage should you have any to assist in diagnosing an item at fault.
This page has the information on boost solenoid valve should this be the item you are trying to locate.
https://www.fiatforum.com/stilo-guides/224083-stilo-jtd-boost-solenoid-valve-resite.html
Hi there guys.I am a bit into trouble with my beloved Stilo 1.9 jtd 85 kw.It all started when I wanted to change the boost valve as I had lack of power and on multiecuscan was showing me an error.So without knowing where this valve is situated went on ebay and bought boost valve.All good.The part arrived and I was trying to change it.This one was another boost valve situated under the Egr valve. I removed all the hoses without taking notice which goes were.after that the car was working even worse.so I had a look on the forum and I have seen that the actual valve is another one and is located under the headlight.So ordered that one and I just replace it today and changed the location on the battery tray.The car goes better but not sure if as it should due to the mixed hoses on the other valve that is underneat egr.Can anyone point me to the right direction how to reconnect the hoses in the right order?From what I,ve seen,one hose is coming from abs pump.another one is coming from the turbo boost valve,and the other one is coming from a vacuum valve.Many thanks
I don't know of any hose coming from the ABS pump.
The only other vacuum valve on the JTD 85kw (115hp) engine is the one that operates the idle shut-off butterfly valve. That one is shown in the diagram below, but I don't recall it being under the EGR valve. If that's not the valve you're talking about, post a picture of it.
this is the one that I am looking for.On mine is situated right under Egr valve.And I don't which hose goes where.The hose that goes into the Abs is actually going into a larger hose and from there into the Abs pump.Do you have a description with what every number on the picture is?Many thanks
