FabssGarage
- Joined
- Jan 13, 2021
- Messages
- 5
Hello guys!!
I'm new here! I'm currently supercharging my little Cinquecento but I have serious issues finding someone to tune my stock ECU. I'm planning to Speeduino it but I don't have the time to mess up with it's assembly, wiring, and tuning from zero. So I really would like to make the IAW 16F ecu to read boost. I know I have to buy another map sensor as the stock one reads up to 1,05bar absolute pressure.
This is my setup:
-Fully stock engine and compression
-Boost will be kept to about 0,65bar using a 0.5L Roots type amr500 supercharger with 1:1.75 pulley ratio in a draw through configuration to avoid the use of an intercooler.
-38mm Lancia Dedra 1.6i.e Weber-Marelli TBI using it's stock black top injector
-Adjustable boost based FPR
-Less restrictive exhaust and also decated
-#866 camshaft
Info that maybe could be needed: the car is a/c equipped, it currently still have the cat (will be removed next week) and stock lambda sensor, and I have also installed a AFR gauge. All the ignition parts have been renewed, fresh 10w40 oil and new fuel filter.
I really hope someone helps me as soon as possible.
I appreciate your help guys.
Cheers!
This is my setup:
-#866 camshaft
Cheers!
