Technical Bonnet Catch !
Mike57
Loftus, Cleveland.
Hi Guys, after I open the bonnet to check the oil, water & other stuff and go to close it some times it wont close so I have to "Slam" it, then it closes ok But any ideas why, I have it well greased up.
I have a similar issue.
It could be that the catch needs cleaning up and regreasing, it sometimes sticks in the wrong position.
You can check this easily - if it bounces when you close it, grab the release cable and shove it to the left. You'll see the catch reset, then the bonnet will close OK.
If that's the case, you can take it off the car, clean up and regrease to fix it
a1ant
-~Moderator~-
Staff member
UK
Hi mate,
When the bonnet won't close, is the bonnet release handle in the footwell loose (ie no resistance when pulled). If so it means one of two things, your cable is knackered and may be about to fail. See guides section on what to look for on the cable. Or the spring locking pin is sticking. They sometimes stick when they get clogged up with grit/grime/rust and the grease almost exacerbates it. You can try stripping it down and giving it a clean with degreaser or wd40 and see if it loosens it up.
If the catch/ cable is springing back as it should, then as old hammer says it might be the bonnet is not aligned correctly, although unless you've had a minor bump or new bonnet etc, if it's been working correctly up untill recently I'd suspect the cable or catch. There are two little rubber buffers on the front slam panel either side by the headlight, you can try screwing these in by say 1/4 of a turn at a time to let the bonnet sit a bit lower into the catch, but aesthetically you should line it up so it sits flush with the top of the wings.
Alan
Edit atom beat me!
oldhammer
Busy rebuilding pand'a
manchester'ish'
if theyve had abump,even aslight one, it might be out on slam pannel,
you can normaly tell off lower radiator support if theyve had a previous
bump,
i've not had problems with either my punto catchs except the cable and the lever in the car failing
But that might be because i take mine out - and give it a really good clean in a bucket of hot water and dishwasher tablet
ziggy
