My bonnet release has stopped working, any ideas how to open the bonnet without it and then how to fix it? I need to disconnect the battery as I'm currently removing the dash.
How broken is broken? Mine no longer has a handle, and the bonnet is opened by just yanking on the white plastic cable sleeve somewhere near the passengers feet!
The cable (on mine at least) runs close to the front of the car (to the passenger side) so you may be able to remove the grille and reach your hand in - not sure though. This might help to visualise it:
You need someone to assist, pull a bit harder but try not to damage( when handle in max position put on the cable itself)
While one, undo the rubber bunks/ bump stops by quarter of turn, lubricate latch, fit some shims ( washer with slot) to the sleeve end at the latch side.
This tends to happen with age as the cables get stretched and sag so they become difficult to operate, mine ended up this way although unscrewing the rubber bump stops as already suggested does tend to fix it.
