Technical Bolts to Lug Nuts Conversion?
iBstoneyDave
Is it possible to convert from the standard wheel bolts we get here in the EU to using lug nuts/studs?
And more important is there any downside to doing it if it is possible?
Eklipze3k
No strings on me
Staff member
Huddersfield
Definitely possible, only complicated issue is making sure you get the right length studs. I converted my Mk2b to studs, bought what I thought would be the right length and they ended up poking out past the wheels! Luckily I had some 10mm spacers which I could fit but given the chance, I'd have soon just bought shorter studs.
These were what I bought, so 50mm nuts side thread is way too much, I'd say 30mm would be plenty.
g8rpi
Moderator
Staff member
Cambridge
The only two reasons I can see are so you can use "loose" wheel spacers or because it's a bit easier to fit the wheel with studs (option buy a guide stud)
If you do use these studs I suggest good cleaning and use of quality thread locking compound on the end that goes in the hub.
Robert G8RPI.
Eklipze3k
No strings on me
Staff member
Huddersfield
For what it's worth my spacers are hubcentric. Main reason I fitted studs is because I do all of my own maintenance, which often involves removing the wheels, I just find the studs make them much easier to put back on.
Did tje grande loose the 2 locator lugs that the mk2 / mk2b punto had?
Failing that - if its pure and simply a refitting the wheel issue
Why not buy some long lengths of rod of same pitch/dia
When u remove 2 wheels u out the rods in
And then remove last 2 nuts
That what u have 2 locator lugs when putting the wheel on
I believe the stilo had a fitting bar like what ive described in the spare tyre kits
Ziggy
aurick86
Well-known member
Bucharest
That is the what the red bit does... it's threaded at one end.. so you can screw it into one of the holes, then put the wheel on it, add the other bolts, unscrew the red one, put in the 4th bolt.
digger58
Well-known member
Limerick
It's a very simple bit of kit and easy to make. Much more cost effective and I'm sure safer than the bolt affair!
aurick86
Well-known member
Bucharest
Now if the OP wanted to go to studs...AND do to a different bolt patter like say 5x114.3 that would be interesting and worth while.
We would be thinking either about machine shops or about off-the-shelf alfa/lancia parts that might be a straight fit.
