blaupunkt radio help
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
rsole
hi new here just got a second hand punto it has a blaupunkt san remo cd 31 radio in it my problem is i have no control of headunit nowt happens when i push buttons when i turn car on unit lights up but just shows 0.00 what i take is the clock for it goes up as i drive but goes back to all zero every time i switch car off do i need a code as previous owner had just put new battery in or is the unit broken
hi thanks for reply its a mk2 03 i have looked on net and seem to find any info how to input code
Blaupunkt San Remo CD31 is not a standard Fiat radio, it's an aftermarket radio.
It has a removable front panel so doesn't have a security code.
If it doesn't remember the time when you switch it off, it's likely to be a problem with the permanent power supply to the radio.
i take the headunit is broke as i can push every button but does nothing apart from light up
