Hi guys, I have a problem with my rear brakes binding, the NS wheel especially.
I've noticed that after the foot brake or handbrake has been pressed and released, the pads are still quite firmly gripping the disc. If I grab the back of the piston and pull it towards the front of the car, you can feel a little 'nudge' and the disc is free to spin again. Its almost as if the caliper is turning a little as it applies pressure to the pads and then because its skewed a little, its locked in that position.
Is it likely something to do with the sliders allowing too much play and not keeping the piston in alignment with the rest of the brake assembly as it applies pressure or something else?
