Best set up- advice please
Gary
Loving the Fiats
in your dreams
At the moment I have a Kenwood Head Unit wired to front speakers 2x50w
Then I have a bridgeable Kenwood 400w amp powering a boxed JBL 12" sub
The question I have is, I have just bought another boxed JBL 12" sub so
1) Should I get another amp and daisy chain it with the other one
2) Should I use the left and right channnels from the amp to power the subs.
3) Should i connect the cable from the two subs and run them off a new more powerful amp.
OP
OP
Gary
Gary
Loving the Fiats
in your dreams
Sorry for the delay, now found the head unit Number
I have also been using the input on the head unit for the Audio from the dvd player
Kenwood w7027 see here
Amp is quite old now and is in the garage so I don't have the model number to hand
chaos
Ah. Not good...
It was the amps and subs I was more interested in TBH Gary :) I can probably tell you what JBL subs you have from a pic if they aren't written on the cone, and the amps are more likely to have the model number written on them :)
chaos
Ah. Not good...
I, err, don't recognise it :eek: I think it may be a predecessor to the GT3/GT4 series :)
chaos
Ah. Not good...
I'm gonna stick my neck out and make a couple of assumptions here :)
Those subs are 4 ohm single voice coil and you need a 2 ohm stable amp if you wire the 2 together to show 2 ohms :) I would try to find out what sort of RMS wattages those subs will take and pick a mono amp accordingly :)
