Technical Best method to adjust new brake shoes and handbrake ?
Guildford
Hi all
My 112 has the same rear brake arrangement as the 127 and the 128 .
I have changed both rear wheel cylinders , fixing springs and shoes .
What the best way to reset the shoe adjusters and handbrake adjustment .
Alex
bugsymike
Prominent member
Torbay
Hi all
Alex
Others may have different ideas, but for me where you have the friction pads with the strong spring type adjuster, you often find pattern brake shoes give a poor foot and handbrake as they can't compete with the brake return springs.
With the handbrake adjustment backed off and the shoes all correctly fitted I use a screwdriver to ease the shoes out slightly so that I can just get the brake drum on, tighten the securing bolt and then give the drum a tap with a copper mallet this allows the shoes to square up in the drum, but still takes up most of the slack, then I operate the hand and foot brake a few times and if the foot brake is acceptable I manually adjust the handbrake cable to feel right then check that the brake drums will spin easily. Finally I roadtest and check again to make sure spinning and not dragging.
If you can only obtain cheap pattern brake shoes with those weak adjusters then a possible fix is to weaken the tension on the return spring near the wheel cylinder slightly. This is a last resort to get a decent pedal and handbrake and not the recommended option.
OP
OP
folgore
Guildford
Well, seem to have a good pedal I need to adjust nthe handbrake lever down to 3 from 6!
bugsymike
Prominent member
Torbay
Should be all good then, always best to check after roadtest in case any binding from over adjustment.
Depending on car but I always liked to have the wheels spinning free, then one click on handbrake you can start to feel it slight drag but by the time I got to three clicks I could undo or tighten the wheel nuts with car off the ground, but that is my preference.
