The #4 Exhaust rocker does not line up on the center of the valve. All the other rockers look OK. Is is bent, or is there a trick to lining the rockers up?
I would make sure you know how they should be before changing them,
rocker arms are often set off centre to put a rotational movement on the
valves to help even out any ware.
