General Battery replacement on key
Ianwm
Aberdeen
How do I replace the battery in the key
I replaced one in my first key but it does not work is there a sequence to follow
Ian
No sequence, the remote should work if the battery is good.
Check the microswitch as this is a known weak point (usually becomes unsoldered and can be repaired at a good electronic shop).
Multimeter would be good to check voltage on fob.
Checked the battery this morning plenty power so decide to open the first key and study it only to I had fitted the battery the wrong way round
Light does not work if battery if fitted incorrectly
Both now working
Thanks for your reply
Ian
