Technical battery light on till 3000rpm
arc
this is where i stand
Manchester
Ive not yet replaced the alternator (will do that this weekend) just think its kinda odd that when i start the car, the battery light will stay on till the car reaches just under 3000rpm. If i then let it fall below, the light doesnt come back on - unless i turn the car off and back on again.
Just seems a bit weird, i would've thought if it wasnt charging right below 3000rpm, the light would come on whenever the revs were below that..
Also, could a dodgy alternator cause a misfire - was pulling onto a roundabout before and all my power went.. then came back again. Always happens at the worst times eh
I had the opposite problem where my alternator would only charge below 3000rpm as the light would come on above and not go back out till it dropped to about 2400rpm. I think it's to do the the voltage regulator in the alternator which can be changed on its own, but why bother, if you've removed it, replace the lot. :)
Aaron.
It can happen, and I think has with yours. Re the misfire, if the alternator suddenly gives 16 volts or 9 then the injection system is going to get the wrong values all over the place, so yes can cause a misfire.
when you say misfire arc do you mean same as i was getting where i would pull onto a roundabout and then it would loose power but still be ticking over and i would have to keep reving it etc giving general abuse and then it suddenly gets power and flies across the roundabout or do you mean for about a second
Have you checked that the battery and earth connections are all tight and intact, sounds as if one of the earth connectors is loose or something...
Paul T
the earths i know are good - ive taken them all off before and sanded the lot down, with a lil bit of copper grease too.
I'm going to change the alternator this weekend, i'm hoping that'll sort it - but if it doesnt Sie said I can give him my old one and he'll give me my money back. So i've nowt to loose by tring it :)
I'l recheck all the earth connectors and battery connections whilst i'm at it
