repeated from elsewhere
but is a permanent change, not recommended for holidaymakers!!
hi, errr this is actually quite easy to do, and ive done it twice!!! bugger.
first i moved from germany to england, then england to sweden thats why i did it twice. You will need to remove both headlamp units, a space alien or capuchin monkey is hand to access the bolts (otherwise you need to take the bumper off, or have lots of extensions for access.
Be gentle on removal cos this can chip the paint around the headlamps.
You will notice in front of the headlamp is a metal plate shaped like ___/ except the ramp is not so steep as i have typed. This has to be reversed. choose your way to do this, i filed mine down and then riveted a new plate for the ramp bit, but use metal cos it has to cope with the heat!!
The main thing to do is measure (or better still make a cardboard template) of the ramp before you cut it down (duh!). then flip it around , balanced on the centre axis of the bulb.
This got me through the uk mot and swedish bilprovningen so it defo works and was perfect on the reflected wall lines. ben email me if u get stuck
[email protected]
