Kevtherockstar
- Joined
- Aug 15, 2018
- Messages
- 17
- Points
- 3
Hi all....PLEASE HELP!!!
Could pack 1 went. Fault code P0351- Change coil pack. Ht leads and sparks. Still wouldn’t work.
Put the ecu wire from coil pack 2 on to coil pack one. Cleared codes. CAr wouldn’t start then I had could pack 2 error.
Plug wire from coil pack one in to could pack two. And car started. Still coil pack two code.
Swapped sparks from cyl 2/3 into cyl 1/4 and vice versa.
And changed coil packs to back standard setup cylinders 2/3 back to normal but still no fire in cyl 1/4
So from what I can gather ...
The issue is NOT Ecu failure.
The issues is NOT HT LEADS
THE ISSUE IS NOT SPARK PLUG
compression test from garage confirmed all okay.
Tried new plug and play ecu just incase, nothing.
So the issue lies directly with cylinders 1/4
WHAT ON GODS EARTH ELSE CLULD BE CAUSING THEM NOT TO FIRE??
