Technical ARB brackets
Sam Pryde
Can anyone help me in the quest for either new front ARB clamp/brackets or the ARB and brackets all together as my bolts snapped after taking it off to do some work! Atempted to drill out and fix but jasnt worked! Need it for the MOT next month! Can anyone help!
Re: Eibach Anti roll bar?
You don't need an ARB for MOT, I did the same with mine and have just left it off. FIAT no longer make the brackets new, however you can get them from Poland, or I think someone (@cc1 ?) has some brand new unused ones for sale too. Have a look in the classifieds :)
I have 3 that have been welded at a slight angle and the top bracket holes are about 1mm out. A tweek in a vice would sort them so will save for my other Schuey.
Understeer/Oversteer. Orthodoxy says that running without a front ARB will promote oversteer (hence, you'll be going through hedges backwards) while running with one will promote understeer (going through hedges forwards).
Of course, it isn't quite that simple in real life........................
