Anti roll bar
Anti roll bar
S
Steve
Hi all,
I haven`t posted on here for a while.
I have noticed recently that my Bravo has started to make a clonking noise from the N/S suspension, all ball joints appear to be ok so this just leaves bushes of some sort, the bttom arm bushes look ok as do the anti roll bar bushes. Is there anything else that you guys know of, common failures or points of wear, i`m thinking it could still be an anti roll bar type fault due to the nature of the noise.
Look OK and are OK are quite often vastly different. The anti-roll bar is a solid rod and only touches the car at the bushes.
If its clonking on the N/S suspension the fault is with the N/S suspension, most likely the lower arm bushes or ball joint.
A
1
239
A
R
1
180
jords
J
P
1
277
Dark Lurker
T
2
249
L
F
5
311
Anonymous
A
