Brymak said:
Hi everyone,
My Uno 60S has developed an annoying habit of not idling. Engine runs smoothly on high rev idle, but as soon as you lift off the accelerator the engine dies. This is intermittant as it only seems to get worse when the engine is at normal temp. I had a complete carb rebuild (Solex) a year ago. Could it be a sticky float chamber valve?
Thanks all. :bang:
This sounds like the infamous distributor vacuum diaphragm!
As yours is an 1987 60S, it should have the 1116cc non-FIRE ohc engine. I thought they had a twin choke Weber, not a Solex?
Anyway, your symptoms match that of a failed vacuum diaphragm. The idle problem gets worse when the engine reaches normal temperature, because being a carburetor engine it needs the choke out until it's warmed up. The choke also raises the idle speed (fast idle), which would help compensate for the failed diaphragm. As soon as you release the choke the idle speed drops, and with the failed vacuum diaphragm you get an air leak into the intake manifold. This upsets the air/ fuel mixture, plus also means that the advance mechanism in the distributor is not operating at low revs.
Find the vacuum pipe that runs from the distributor to the carburetor, and pull off the pipe at the carburetor. Now blow or suck into the pipe. If there is resistance (i.e. a vacuum) then the unit is fine. If there is no resistance then the unit has failed and this is most likely to be your problem.
Get yourself a Haynes or Porter manual, or look in the Uno technical threads as the changing of the diaphragm has been covered many times before. I suspect that if you replace the diaphragm (it's quite an easy job) then your idle problem will be solved.
Good luck!
Chas
