go on ebay get universal pair (check sizes for fit first). to fit to standard lights you remove a light and then remove the glass lense by pulling the metal clips off around it and then lever it off with a screwdriver. to mount the angel eyes inside i'd recommend you use something solid like screws or epoxy resin, its sooo annoying if they move once you've put them back together. as for wiring, use the original sidelight wiring in the light, 2 wires, simple to do. remember the cops will pull you for blue ones, and you'll fail an mot. best to get white they're a bit blue anyway, but the blue ones are very blue.
