Many thanks, yes I will post in the Uno section. I am totally new on here and found the Uno section after I had posted this. Mods might move this for me, it would be better where it belonged.
No problems, and welcome to the forum! I'll ask one of the mods to move this to the Uno section
BTW, we have a few members from NZ who also have Unos. AlexGS has an absolute wealth of Uno knowledge and he might also be able to point you in the right direction for getting spares in NZ too. Hopefully he'll see this thread and let you know.
Oh, and you might end up at a race track with him and JJHepburn if we can get you to connect!
I asked about the bulb because I thought an ordinary bulb would not be strong enough. I figured that was why they put in the one with the magnifying glass on it. Did you put in a 5w bulb or stronger?
To be honest, all my Unos have been so old that the original bulb had long since burnt out before I got them! Therefore I couldn't tell whether the original bulb was brighter or not. I'm not sure what wattage bulb I fitted, but it would have been the same as the original. The switches are perfectly visible at night, not that bright when there's lots of lighting outside, but more than enough to illuminate them. So I'd say just fit a normal bulb with the same wattage as the original.
The thread on the thermostat was good, but sadly my housing is like the one in the Haynes manual and has 3 inlet/outlet pipe connectors. Page 2.3 figure 4.2 and 7.3B.
The housing might be different, but the principles of swapping the thermostat inside will be similar hopefully. You need to see if it is at all possible to remove the thermostate from the housing (you'll have bend/ remove some retaining tabs), and then you'll need to search an auto store to see if you can find a thermostat that is the same size and rating. It can be done I'm sure, but finding a new thermostat complete would be the best option.
Will see how available a new one is from Fiat, but I haven't had any luck so far with after market ones from Tridon. They didn't have reverse light switches either, they are in the book but none in N.Z.
Again, you need some advice from AlexGS. ALEX, WHERE ARE YOU?!!! I'm sure he'll be able to suggest some places for getting spares.
Yes I will post a picture, after I have taken one!! It has done 225000km and in quite good condition for its age, except for the rust around the foolishly designed sunroof. Have to figure out how to fix that permanently, without damaging/buckling the whole roof!!
You have one of the oldest and also a rare model of Uno! 1984 was one of the first years of manufacture (1983 was the first), and the 70S model was only made up until around 1985/86 after which it was superceeded by the 70SX. It should have the clock (red LED with stop watch)/ map reading light/ rear view mirror unit in the roof, electric front windows operated by switches on the centre console rather than the door handles, central locking, instrument cluster with tachometer and incorporating a check panel, and lastly a sunroof (though I think this was an option). Of course it will also have the 1301cc ohc engine with twin Weber carburetor that gives VERY respectable performance for a 1984 1.3 litre.
As for the sunroof, I take it you have the tilt and slide unit? With the rotary handle fitted in front of the clock? If so, it's the same as mine! They're great when they are working properly, but if they seize up then they can break handles, not close properly, leak and also rust around the edges. I was incredibly lucky in that mine had no rust around the edge whatsoever, so as I had a dodgy seal I removed the whole assemble and treated it to make sure no rust will come back.
You can read a step by step guide as to how I did it here:
https://www.fiatforum.com/uno/19781-rust-around-sunroof.html
Anyway, good luck with your Uno and please do post some pictures! It's always nice to see some pictures of old survivors
