- What equipment do you have?
Standard Sony headunit, a Juice amp, 4"Pioneers in front, Ministry of Sound 6x9s in the parcel shelf and a JBL sub in the boot
- What exactly is the problem? For example, do any lights come on, is there a distorted sound, etc.
When I connect the Remote cable from the radio to the amp (the wire that tells the amp that the radio is on, and to turn itself on), the "Prot" (auto protection cut out) light comes on and there is no sound to the sub or the 6x9s.
- Have you made any recent changes to your system?
This is a re-install after I took it out (I think I had the same problem then) but the main thing is that is
has worked fine in the exact same setup in this vehicle and in another one previously.
- Have you checked anything to try and eliminate them, e.g. have you checked your earthing point(s)?
Earths have been checked (it sparks so there is a good circuit), checked the inline fuse as well as the fuse on the back of the amp, checked polarities and checked connections.
Any idea what's going on with this?
The power light on the amp comes on, so there is power getting to it, and the manual says that it has "thermal, over-voltage and short circuit" protection, but none of these seem to be happening.
Im stumped. :bang:
Can post up a circuit diagram if needed.
