- Joined
- Nov 6, 2008
- Messages
- 65
- Points
- 30
Hello All
PLEASE can anyone advise me about this problem, the warning lamp is constantly on showing a BATTERY in RED on my PUNTO 1.2S 1998 model.
Obvious reaction is ALTERNATER failed but has it, my first test was to put a multi meter accross the battery with the engine OFF, meter reads 12.53 volts ... started engine same test at idle speed meter reads 12.08 volts.
I would have thought even at idle speed a small rise in voltage should be shown ... am I thinking correctly here ?
Have read older posts saying possible REGULATER fault, not sure if the REGULATER is inside or fitted to the ALTERNATER itself.
Have visually checked lead to battery these are securly fitted have pulled/pushed etc to see if there loose but appear o.k.
Any infos/tests I can do would be appreciated
