Technical alloys
Technical alloys
steveEC
edinburgh, United Kingdom.
Hi just new here! was wondering if any1 could help me im looking 2 get some alloys for my chonki but im finding it realy hard! any help would be appreciated :)
welcome, another Scot, excellent.
A dig through the search fubction should turn up all you need to know, and then join Clubcento and get even more help.
cheers
Grumpy old git going fast downhill rather than downhill fast!!
Weird width? Its only 13x5.5" thats a standard size...its the PCD (distance between mounting holes) I'd be more worried about..
If yure feeling crazy, or like the mini look, Mini wheels or Rover \MG\BL Metro\100 or whateverthe fooq they are called are 4x4" PCD = 4 * 102...Fiats are 4* 98,
so yu can slide on mini wheels using wobbly bolts!
Tom (AofB)
95 Cinq Sporting - Rattly GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses, 10" Sub and 6x9's.
1242cc Engine to go in soon, boot delock soon, ETech Wing still in garage, so's the effing K+N!
Go and get some 14"s in a vauxhall fitment. the pcd is only 4x100 so the wobbly bolts will do it. Think they are £3 per bolt at motorworld and the locking wobbly bolts are £30. Brand new 14"s with tyres shouldn't be much more than £400.
Yellow Cinq Sporting​
Lowered 40 On Spax Springs and Dampers​
Alpine mp3 Head Unit​
Alpine Monoblock Digital Amp​
Infinity 4" Fronts​
Infinity 6" x 9"s In Stealth Shelf​
Infinity 12" Sub​
Full Powerflow Exhaust​
Tinted Windows On The 1st Of June​
The PCD for your car is 98mm, Most four stud Vauxhall/Opels and most four stud VW's( and clones) use a PCD of 100mm. Its only imm out each side. 'Wobbly' bolts are bolts that have a wobbly head that will take up the 1mm difference, allowing you to fit said 100mm PCD wheels.
That nowt to do with PCD. Scrubbage on the inside of the rim is a function of brakes to big for wheel. Standard Cento brakes will fit inside 13 inch rims. Anything bigger, you need 14s. Scrubbage on the arch, or suspension is a function of offset. This is the distance between the mounting face of the wheel and the centre of the wheel, in section. Cento, IIRC is 29mm, vauxhall 49mm, therefore you would need 20mm spacers, not good. Punto wheels are 38mm, therefore 10 mm spacers, which are OK.
