alloy wheels
alloy wheels
I
ian
can some one help want is the biggest alloy you can put on a bravo thanks
Re: Re: alloy wheels
19's will go on, but with major arch work, no full lock and you'll not be able to lower it.
18's will go straight on with a bit of rubbing (inside front wheel archs and on the rear with passengers or ICE in the back), again you may struggle to lower it.
17's go straight on, no arch work, full lock and you can lower it by 40mm before having to do any arch cutting.
Re: Re: Re: alloy wheels
And I'm sure 21's will go on if you remove the Quaterfront/rear panels. :)
alloys
the biggest wheels you can put on a Bravo WITHOUT the arches being rolled(upto £200) are 17" by 7".
you can then lower it by 40mm,have 2 rear passengers and the tyres still won't rub against the arches
g.r.e.g
alloys
The biggest wheels you can put on a Bravo WITHOUT the arches being rolled(upto £200) are 17" by 7".
Does this also apply to the Marea?
Re: alloys
i dunno mate, sorry i would have thought so though
