Hello from Jersey. Just bought a La Prima Convertible, 2 years old with only 4,000 miles on it. Absolutely pristine. It cvame from Guernsey (even smaller island), which explains the low mileage.
Not my first EV (I also have a KIA SoulEV), so its more a case of learning the differences between them, and there are plenty. For an example, why does it require the EPB to be manually released to back out of the garage, but not at other times - eventually found the relevant section in the manual, and, yes, I didn't have the seat belt on!
And you can't switch the headlamps off, and when they come on by themselves because you've driven under a section with tree foliage overhead, the display panel in front of you dims so much you can't read the symbols and small script with sunglasses on. I found the brightness settings and set the level to maximum (10), but its still not enough. If someone has a fix, other than taking the sunnies off under each section of trees (and there are plenty), please let me know.
But everyday driving is a delight when the sun shines and the roof is open. The car has replaced a Peugeot 206CC, and the joy of opening/closing without having to stop.....
I still feel I need a pre-flight checklist when I get in, but its fun. And I love the one pedal driving. I've settled on Sherpa Mode, which means I control the Climate, something I prefer, but if I was happy to leave it to the car, there's Range Mode, so a great piece of design. So far, I've seen 5.1 m/kWh, which is a bit better than the KIA (about 4.9 under the same conditions). I calculate that, if the car still has the 38.3 kWh useable capacity, it needs to average 5.22 to make 200 miles range, but the GoM shows only 160, so it is still learning (I hope), or the battery has lost a lot of capacity.
