Sorry for starting a new thread but ive spent weeks trailing forums, using the search options and trying various things, also I should probably mention I have a Fiat Punto Mk2, ELX if it makes any difference.
I brought my alarm system several weeks ago but have been struggling with the negative and positive door trigger wires
Everything else is in, Central Locking, Indicator/Side Light, Electric Window output, Tilt Sensor and Siren. The only other thing i havent put in is the relay (imobiliser) as the alarm spends most of its time disconected
I tried the pdf on the security section sticky but encountered the following problems, where it indicates door and boot wires for the switches it doesnt say which is pos and which is neg, also it states pin 21 for the door wire but the info @
https://www.fiatforum.com/punto-ii/236297-body-computer-pinout-here.html
states pin 21 is Courtesy lamp timer control :bang:
also at the link above it says pins 1 and 11 are door switches (and so does haynes manual ) yet pins 1 and 11 aret used on the bottom left black connector with the red clip and ive seen this said in other security/wiring threads on here :bang:
i tried both wires anyway, alrmed car and opened door and boot, nothing :bang:
so i tried the other way round, this time the alarm beeps when arming (currently on chirpless mode) so its indicating something wrong, a min or so later the alarm chirps 3 times and will continue doing this every several mins, acording to the book 3 chirps indicates door sensor :bang:
My latest attempt involved removing the door card and running a wire direct to the door switch, first problem was that the door woring is joined by a plug :bang:, easy enough to connect wire to footwell side of the door connection, the door lock mechanism (driver side) has the following wires
Thick Grey
Black + White
Brown + Grey
Thick Yellow
Black + Pink
Black + Blue
im assuming that if i find the correct wires i can use them.
someone please help
Thick Grey
Black + White
Brown + Grey
Thick Yellow
Black + Pink
Black + Blue
someone please help
