tonyholbury
- Joined
- May 6, 2021
- Messages
- 12
- Points
- 6
Purchased a 2008 1.1 Panda earlier this year with both airbag lights on and no horn.
Replaced control stalks/clockspring unit, I managed to get one brand new on ebay for £25 yes £25 as a garage had purchased it and the owner had scrapped the car that was damn lucky!!
No communication so purchased a 2nd hand sensor unit for £11
Purchased a brand new passenger airbag switch for £39 its the same as the punto one.
After fitting the units I removed the sensor unit and put back the original the switch reset the passenger warning light and replacing the sensor turned out the main airbag warning light. (different coding??)
Sensor is on the floor behind the bottom of the centre console you can get at it by removing the passenger side panel and its 3 10mm bolts, the plugs are sliders with a locking tab there is enough wire to see this.
The busted Horn was due to the clockspring, possibly the original fault with the airbag and the passenger switch I am guessing got broken on removal as the plug socket sticks out at 90 degrees and is easily damaged.
Anyhow both lights out they reset by themselves once the faults were fixed, I did clear the fault codes with an ebay switchable OBD2 plug and paid £50 for the Multiecuscan software which works with this plug and ELM27 units I could have left out the clearing process and saved some money but hey ho we live and learn and thats why I have been so detailed to save you guys paying out, if its both lights its probably the passenger switch has been broken (both light) Horn/ Main Airbag then its probably the clockspring the whole stalk and spring unit is one piece so if its too expensive try a breaker for a 2nd hand part.
Tony
PS if you do need to replace the sensor watch one thing some cars have pretensioners/seat belt switches, try to get a module for a similar car, it mmay need recoding as my replacement didnt work but the original did, my car has niether pretensioners not seat belt warning lights/passenger presence switches and zero wiring under the seat
Tony
