I know Peter spoke about this a while back but over the weekend I worked on a 650 Weber 28IMB for a guy who said it did not run well and leaked petrol. Apart from an issue with the idle mixture jet I could not find any fault apart from a minor bow on the top cover and the float needed adjusting. The guy had only just bought a new refurbish kit from a well known South London Fiat specialist outlet. I decided to change the carb top cover and when swapping over the large gasket I felt it was a little flimsy. So out came the vernier callipers and the new gasket was about 40% thinner than an old one I had. So new/old gasket fitted and went to adjust the float and suddenly it was spot on. When I changed the carb top I had left the old inlet valve set in place. The old original inlet valve was taller than the new one hence the adjustment being right. So much for the new refurbish kit.
