Advice on fitting lowering springs
R
ROBIN
Hi all, has any one got any a advice I may need on fitting my lowering springs I know the rears are easy but are the front? I have lowere my mondeo st24 a couple of years ago so I am not worried about doing it but wanted to know if there were any tricky bits?
Robin
Fiat Marea Weekend 2.0 20v HLX 147 83k and so far so good!
Try beg/borrow/steal a compressor and air ratchet, makes taking the top nut off loads easier ;) and make sure you have the spring clamped down real good, cause i nearly killed someone with mine when i did it haha!
I have a compressor but no ratchet, when you talk about the top nut do you mean the main one that holds the spring clamped in?
I have spring compressors too but I will be wrapping wire round them too for double safety.
The rears are easy I remember taking the rears off if rat2.
robin
Check out the repair guide, Sven has done a guide for the fronts and I think bravopro(?) has done one for the rear.
Stephend
Yer robin, the nuts that hold the actual spring on, pretty sure you can do em without though, just makes em a lot easier!
Good luck fella, remeber to update your project log!
one bit of advice...check the camber. get a camber alignment tool to make sure u line them up properly.
another word of advice...get a proper night sleep before hand...it might kill u if u dont lol
I haven't got a cambe alingment tool, but I jut need to get them in as my wife keeps stunning here toe on the box and is getting the hump lol, the shoucks will be coming off again for a clean and paint up, when I do that I will get the camber set right
cheers
robin
Rears are done which were a bit if a knightmare invthe end, wouldn't of been I I had just done what I said u was gonna do in the first place nut I got caught up invthe momemt lol, but the back is very low, gonna do the front in Friday or Monday just need to et me a 18mm spanner then it will be easy.
robin
B
1
312
J
F
7K
F1-ANG
F
C
232
Craig
C
E
889
E
