Ok guys, here's my problem. I have a 2007 GP Starjet, and about a week ago my AC and Ventilation both stopped working. I plan to visit a service anytime now, but the fact is that outside is hellishly hot and I still have work to do. So, not knowing if I'll be able to find enough time to get the car to the service, I was hoping you guys could help me out. The facts are as follows: Up until then, I had absolutely no issues whatsoever with my AC or ventilation system. The system is a climatronic unit (auto bi-zonal) and it worked fine until I wanted to turn off the recirculation. 15 minutes after doing that I realized the fan wasn't working anymore. Since then, I've checked the pressure in the instalation(ok), I've checked the control unit connectors(works fine), I've tried to do a reset of the control unit (didn't help), and even tried to figure out where that resistor is located (I haven't found it until now - so maybe you can help). Also, I've changed the fuses related to the AC or fan control and still no go. The fan isn't working - be it with the compressor on or off. What I did find out though, as you can see in the pictures, was that one of the connectors has somehow managed to melt - but the fact is I don't know whether this is the cause or an effect for my problems. Any help is welcome. Thanks.
