Technical ABS light on
waynedear
2007 1.9 multi sporting.
I had the front wheel bearings changed and put 1 new abs sensor in as the old one came out in 4 pieces.
Everything back together and I have an orange abs light.
Couple of questions, do the front wheels have reluctor rings ?… does the car need to be driven a certain distance and reach a certain speed to reset itself ? (had that on a bmw bike).
I have decent disks and pads, wiring seems ok.
Read something about the abs pump connection plug, not touched that yet as it all worked before the new bearings.
The mechanic who I trust said it was the worst bearing job he had ever done…😁
Suggestions welcome.
Cheers Wayne 👍
OP
OP
W
waynedear
Cheers Wayne 👍
All sorted, bit of contact cleaner in the abs pump connector and in and out a dozen times (it looked spotless), swapped the sensor leads over and now the abs light goes out with the rest of them. 😁
