Technical ABS BRAKE Fiat punto 176 1.6 90 ELX
PuntoBulgaria
want to ask what is the order of deaeration of the brake system of 176 with ABS ... Is the ABS pump deaerated, is there a plug? thanks
blu73
The Force is strong with this one.
Staff member
Luke's Jedi Academy
left hand rear
right hand front
right hand rear
left hand front
nothing needs doing at the abs pump ;) Only thing to remember really is there is a proportioning valve, so if the cars in the air you will need to raise up the rear axle so the valve remains open during the bleeding procedure.
OP
OP
P
PuntoBulgaria
Are you sure the brake system is crosswise? As far as I know it starts from the farthest wheel rear right, rear left, front right, in front of the left ...I know about the scales on the rear axle ...
blu73
Staff member
Luke's Jedi Academy
i copied it straight out of the haynes, i'll be honest I'd have just done it the way you suggest without looking it up but wanted to check and not tell lies before i posted so got my haynes out and thats what it said.. :shrug:
Sure either way will work just fine if you go round twice though lol
