they may bolt on without spacers but you are reducing the track of the car making it understeer even more than it does, this is not advisable.
this has been written so many times its getting tiresome.
The Sei wheels come with ET36mm, but have 10mm spacers at the front only, none on rear so ET26mm front ET36mm rear. Cinq wheels are ET30.5, but come with 3mm spacers at front onnly therefore ET27.5mm front ET30.5mm rear.
Therefore if buying these wheels if they do not come with the Fiat supplied spacers and stud/nut conversion they are not worth anymore than £100 as these cost about £90 alone from Fiat, tho you can pick up good spacers none of that crapola universal ones for about £30 plus either longer bolts or more preferable stud/nut conversion can be made up from Rally Design for about £30 as well.
All this information is readily available on here with search facility.
Aaron.
