Hello all just got a few problems on the HGT.
First off a while back both my front bumper fog lights just stopped working,the switch came on but no lights.tested the bulbs all and fuse,all was ok.I assumed the power plug had come loose after my bumper was removed during repair,they worked fine after bumper replacement by the way.Recently when i was fitting my neew brakes i decided to take the arch panel off and sort it out.When i checked the plug it was ok but it only had about 3 volts going to thr main connector.i'm no electrician but i'm sure that aint enough.The power at the switch seems ok so i was wondering if there was a relay or summat in between that could be causing the fault.We even stuck the plug to a battrey and the lights came on fine.Any help on that appreciated.
Second prob is over the past few weeks ive noticed that my drivers seat seems ,well a bit wobbly.like its loose somewhere but all the bolts are really tight.I'm sure i seen a post about a common bravo problem a while back but could not find it,again help appreciated.
And finally I have noticed a knocking noise from my left rear when i go round a left bend.At first thought it was the rear seat holder so done the insulation tape fix but not that.Even took out the spare wheel,parcel shelf and folded the seats still there.The car handles fine but its just really annoying.The only thing i could think of was a few years back on my rs turbo a rear bush was worn causing a similar type of knock!!Is there a similar setup on the bravo again any help is more than welcome.
Sorry for the essay like post,hope its not broke any rules about being too long(or boring lol).Cheers for any help
Al
Al
